3M DINOC Interior Wrap Beginning to End
Personally I would not try this, the surface is to slick for the CC to adhere properly. Just my .02
---------- Post added at 03:15 PM ---------- Previous post was at 03:13 PM ----------
The Vinyl is cheap enough to re-apply if it becomes scratched or damaged.
is there an online DIY on how to disassemble the interior pieces? This is something I'm definitely looking to do on mine.
My shifter stack area is full of scratches and some dents..the CF vinyl would make it look 100 times better!
Nothing fully official, but you can follow this link with written step by step info on removing the trim pieces.
It's really easy. If you have the service manual you can also check there
https://www.infinitiscene.com/searc...this-CF-interior-dash-kit?p=274099#post274099
Looking to do mine as well.. im in Vancouver too I got a frickn dent so annoying!
---------- Post added at 01:34 PM ---------- Previous post was at 01:32 PM ----------
same. prev owner manage to get a dent by the shifter.. wtf how is that possible u gotta have a set of keys weighing 40 lbs to push it in like that.. not sure if wrap will even suffice.
should I take a pic for suggestions?
Approximately how many square feet did you need in order to do all of the interior pieces? Was looking into this mod as well and could definitely use some insight. Thanks
to do all the interior pieces about 4 square feet. if you plan to make it perfect, or havnt wrapped before buy 6 square feet to be safe.
Note: This is if you want to do all the silver pieces including the door handles, steering wheel covers, and the center console area.
