350z/G35 Differential Brace Compatibility
falcondrgn
2006 FX35
Hi,
Has anyone ever installed a 350z/G35 differential brace to their 1st Gen FX? Does anyone know if it is compatible? I was looking at the GKTech one and curious if these would have any benefits. Thanks all in advance.
Z33 350z/G35 Diff Brace
Hi,
Did you ever end up buying one? I can't seem to find any information online if any of the aftermarket diff braces fit.
looks like you have a 2nd gen, mines is a first gen so not sure if the 370z's would fit the 2nd gen fx
I'm going to give it a shot! You confirming that their brace fits the 1st Gen FX gives me confidence that the 370/G37 brace will fit my car as the mounting point is there. If not, not a big deal as eBay is easy with returns. I will report back!
It does NOT FIT! The 2nd Gen's mounting hole on the subframe cross member is higher up than on the G37 or 370z. The only way to make it work would be to drill your own hole, but I believe that can only be done with the diff dropped due to space/clearance.
