2010 FX35 Waterpump
Who_Ryder1
New York City
Infiniti FX35 AWD
Who
Hi Guys,
im planning on replacing my waterpump, coolant temp sensor and thermostat as preventative maintenance. The parts in there were all original parts and i want to be proactive and not have the water pump die on me as i plan on keeping the car for a littl while longer. i have 174K miles.
My question is, Ive looked everywhere and only see water pumps being swapped out for the older gen FX's. when i look at engine photos i dont see where anyoen would access the water pump without removing the pulleys and front engine metal covers with VVT's.
(images attached for reference)
How would a mechanic get access to the pump. Also, I plan on ordering the Geniune Inifinit Water pumps and parts, how much would labor be?
I just found this video:
The HR engines require the timing cover to be removed to install new Water Pump. Looks and sounds costly. I'll get a quote tomorrow and let you guys know.
I guess i'll have them do the chains and tensionsers while they're in there as well.
i was just quoted by a local "reputable" shop... lol
Cylinder Head Gasket(s)
Remove and Replace components as required to access and install materials, and/or perform needed service, adjustments as
required. Additional fluids may be required to complete this service. Retest and verify repair as required. Perform final road test where
applicable.
Labor 25 Hour $3,125.00 S
Cylinder Head Gasket Set 1 Unit $476.66 (these are 62.87 directly form Infiniti)
Head Bolt Kit 2 Unit $379.92 (these are 40.00 from Infiniti)
Spark Plugs 6 Unit $179.34 (40.00 for 6 Iridium from Amazon)
Thermostat 1 Unit $37.00 (already have)
Thermostat Gasket 1 Unit $10.32 (Already Have)
Water Pump 1 Unit $198.00 (Already HAVE [75.00 from Infiniti)
Antifreeze 3 Unit $84.00
Engine Oil 5 Unit $62.50
Oil Filter 1 Unit $6.00
Sub $4,558.74
And an additional 800.00 for timing chain and pulleys. lol
