JamFX45ster
- Modesto, ca
Does it move up or down a lot?
I had mine fixed at the dealership, no questions asked. Out of warranty.
I just got mine fixed today after 2 years. It got worse it always stayed on empty so called up consumer affairs complained and got my fuel pump changed. So far so good
The problem you described sound just like mine. The gas gauge is not showing the correct level of gas in the tank. The gauge said its empty yet when to go fill it up it only take 14 -15 sometime gallon. Do a quick check when your gas gauge said its empty by open up the gas tank using the DIY AeroBFA refer you too. I bet that you will be surprise to see a quarter tank left. If that the case, follow through with the DYI and clean the floater arm contacts. Remember to clean the contacts on the other floater arm too. My gas gauge still showing the correct gas level since the DIY.
