2004 INFINITI FX35 with Pioneer Double Din Head Unit and Custom Suede Headliner
^Hahaha, you guys are too funny. You pick :)))))))
This is an awesome upgrade! I have never seen the radio display switched out on the FX. You did an excellent job on the install!
Hi OP, how do you see your climate controls and check your other display settings such as maintenance?
Nice work.
OEM Display is relocated where the clock use to be(all info is visible):
Oh, you didn't see the stock screen moved to where the clock used to be? Right in front of the shift knob.
did you use plastic paint on the grab handles and map lights or purchase replacement parts in black? if you purchased them and have a list of part numbers, please post them!
I used the Rustoleum "satin dark walnut" spray paint to match the headliner color
///7668[/ATTACH]
Hey Zebra I have a question. From your pic I see you relocated you OEM system from the old ...... to the new (where the clock use to be) correct which then means that you removed the controls with it? which i dont see or you are only using th eold system only for AUX and Heat/Air and you just use the touch on the New System?
I removed all buttons that were associated with the old Bose unit. The rest works as before(trip,heat, AC, etc)
very nice, love the suede interior!
i would love to do that in the future in Alcantara on head liner ^^
Love the setup, I admire your work, I have been researching an aftermarket nav add-on with the relocation of the stock LCD, how hard was it? Just extending the wiring? Do you have any photos or diagrams on what you did two relocate the screen?
Thanks!
