- 2010 Honda Crosstour
Didn't even know that stillen had a new intake system out. I like the look of this one..:top:
It's made by:
AFE Filters and it's the Magnum FORCE Stage 2 Cold Air Intake System
So I called Stillen and they said it's good bue they recommend me getting the Stillen intake system which is like $30.00 cheaper. What do you guys think?
AFE Magnum Force Stage 2 Cold Air Intake System:
Features
- Replaces factory air box.
- Replaces stock air filter.
- Replaces factory intake tube.
- Washable/reusable air filter.
- Black textured molded tube.
Benefits
- Up to 50 HP Gain.
- Increase ft-lbs of torque.
- Improves airflow up to 75%.
- Improves throttle response.
- Improves acceleration.
- Improves fuel efficiency.
More Air Equals More Power
For the automotive enthusiast who want all the power and torque he can get, aFe designed the top-of-the-line Magnum FORCE Stage 2 cold air intake system. Whether it is an spark-ignition gas or a compression-ignition diesel, the more air the engine receives, the more power it generates. For powered enhanced vehicles, whether equipped with turbocharger, NOS, propane, performance module; without more air, you are not getting maximum power. The Magnum FORCE Stage 2 systems provide all the air you need.
Compared to our other systems, the Magnum FORCE Stage 2 intake system replaces the entire stock air induction system to the throttle body or turbo housing. Remembering our motto “Stock Sucks”, they eliminate the stock air box, the stock air filter and the stock intake tract. The only thing retained is the stock electronics. They make sure that our Stage 2 system like all our intake systems works with the stock electronics.
Cold Air Equals More Power
In designing out the stock air box, they design in the largest air box that they can for each vehicle application. Even though they make it as large as possible, they are careful to use that stock mounting points. There is no need to cut or drill anything when you install our kits. They make the air box as large as possible so that they can get the largest air filter.
At first glance you probably won’t notice the unique features that they design into each air box. Each of them is there for a purpose, either to make your job of installing the system easier or to improve the performance of your vehicle. Here are a few the features and benefits that distinguish aFe's Magnum FORCE Stage 2 intake systems:
- 16-gauge powder-coated steel – Durable, OE look finish
- Trim sealed or covered – Seals out hot engine air
- Secured PEM-nuts – Easier installation
- Welded and preassembled sheet metal – Faster Installation
- Pre-positioned opening for Stock attachments - No dangling wires, relocating hoses or tubes.
- 3-angle velocity stack adaptor on some applications
- Powder-coated covers on some applications
As you can see, they put in a lot of effort to designing each air box to fit each vehicle. It takes us a little more time and effort but they do it to make the job of installing our systems easier.
Performance Starts With The Air Filter
Since they make our own filters, they can design our filters for each vehicle like they do with our air boxes. By designing the largest filter for the largest air box, they are able insure that the vehicle is getting the maximum amount of air regardless of the performance upgrades.
The Magnum FORCE Stage 2 intake system uses their conical universal clamp-on filters. They make the filter taller, fatter, shorter, or oval to insure maximum airflow for the vehicle.
Here are some common characteristics of their air filters:
- 100% poly urethane construction – Durable, resistant to high temperature and chemicals
- Deep pleats – Greater flow and dust holding capacity
- Rounded pleat geometry – Better airflow characteristics
- Full or modified velocity stack – Better airflow characteristics
- Washable/reusable filter media – Longer service life.
The Right Flow At The Right Place
Letting more air in through the filter and keeping the hot air out doesn’t help much if you can’t get the air to the motor smoothly and efficiently. Some intake tracts are better than others but there’s always room for improvement. That is what they do with their intake tube. their intakes systems use heat blocking molded tubes because you just can’t bend a steel or aluminum tube to accommodate the modern engine compartment. With a molded tube, you can remove kinks, sharp bends and obstructions that restrict airflow. By tapering the tube, you can accelerate the airflow for more torque and better throttle response.
Whenever they design a new intake tube, the biggest challenge is the factory Mass Airflow Sensor. You just can’t place the MAF sensor any place. The modern MAF sensor is sensitive to changes in air speed and volume. Slight changes can improve performance or it can trigger the Check Engine Light (CEL). They design their tube so that the factory MAF sensor is positioned in just the right place so that you get the best performance possible without triggering the CEL.
With the installation of one of their Stage 2 intake systems, you’re ready for other more upgrades like exhausts and performance modules that will give you even more power.
