skagen6675
Is there any instructions on how to replace radiator?
Just did my 04 recently. Extremely easy to do. 2 clips knobs on top, the hoses on the bottom. Then pull out. The radiator is held to the fans by 2 screws.
That's it.
Sent from my SM-G935V
I just went to pepboys and got the spectra premium radiator cu2683. It's around $160 with the 20% off if your order online and pick up in store.What Brand did you use?
Sorry to kick an old thread up but I can’t seem to find the write upDo you have the FSM? In the CO section, there's a full write-up about removal and installation of the radiator.
Sounds more like a bad coolant control valve or a clogged heater core than a radiator problem.I ended up using the Denso 221-3244 that some folks had suggested. $85 on amazon. One thing I will say, is that the air filter is definitely in the way. Spent an unnecessary hour trying to figure out how to pull fan unit and old radiator out. I didn't see that detail mentioned anywhere so I figure I would save someone the headache....(and the time).
I also broke one of the brackets for 1 of the 2 screws on the fan unit haha....so I have ziptied it snug on that side until I figure out the more permanent solution. For some reason, My heat refuses to come on, even after my car has warmed up to temp...not sure if its just brick outside, or if we inadvertently messed something else up.
