Rip, I thought Andy installed a first Generation camber kit on your ride, no?
For the rear yes but it didn't correct the negative camber
How much negative camber on the rear you have right now?
look at the first page of this thread.Who's Ed ? What was the deal if up don't mind me asking
I'm looking for a coil over set up as well
Ya after I just bought the rotors pads and got my 60k service... I'll have to wait a bitJust do it!![]()
$995 shipped(free tracking and insurance) and your choice of Muteki Lug nuts(any color)***, BC Racing Rear Extenders(pick one) or flat rate shipping to Canada($60-$85). Or for 2nd Generation owners Megan camber kit for ONLY $640 extra, both front and rear Megan control arms!So what are the deals for 2nd gens?
Black lugs 12x1.25??Authorized BC Racing NA dealer. Full US warranty. Custom spring rates and "Extreme Low" kits at now extra charge. This offer is only available for InfinitiScene members.
$995 shipped(free tracking and insurance) and your choice of Muteki Lug nuts(any color)***, SPC rear camber kit, BC Racing Rear Extenders(pick one) or flat rate shipping to Canada($60-$85). Or for 2nd Generation owners Megan camber kit for ONLY $640 extra, both front and rear Megan control arms!
Payment method:
PayPal (no fee for InfinitiScene members)
Feel free to post your inquiries here or PM me with any questions or concerns.
* $35 extra for Chrome Neon and Burned Blue Neon colors
** SR48 locks are available, sold separately in packs of 4.
BC Racing's BR model is perfect for street driving and occasional road course duty. With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride height, having a performance coilover system couldn’t be any easier. You choose how low or high you want your vehicle, no preset ride height here, and their patented concave lower locking ring keeps it locked in. All of the systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response. BC’s available front and rear camber plates also allow you to get the perfect alignment setup without compromise. All this while providing a strong, attractive looking coilover system.
General:
- Mono-tube shock design
- 30 levels of damping force adjustment
- Separate Full length height adjustable
- Inverted and Non-Inverted setups
- One year warranty
- Rebuildable
- Adjustable rear camber plates(where available)
- Custom spring rates available as well as a SWIFT springs upgrade available upon request for extra charge*
Technical:
- Coilovers use 46mm pistons and 53mm shock housings, the enlarged shock cartridges with specially designed pistons and rods provide a wide range of damping force
- Valves are constructed of special spring steel, which outperforms stainless steels and produces longer valve life. Valve stacks use a patented deflective system to provide more precise control
- Patented concave lower locking ring, to prevent unseating
- Springs are made of SAE9254 high strength, durable steel.Compression tested at over 500,000 times with less than 5% deformation
- High pressure inner rod guide seals ensure a perfect fit for consistent fade resistant damping and long shock life
- 2 step coating process utilizing nickel and chromium plating to prevent corrosion
- Newly developed lubricant oil in all shock cartridges minimizes aeration and cavitation
- An additional bearing beneath each pillowball mount provides a smooth action and prolongs the life of the pillowball itself
- T6061 Aluminum utilized in spring locks and seats for high strength and lightweight
- Iron lower brackets on McPherson struts to ensure rigidity
- Piston rods are constructed of highly polished steel to lengthen oil seal life and prevent leaking
Muteki lug nuts:
SR48
Get race car functional design, OEM quality construction, and car show class looks with the Muteki SR48 Lug Nut Sets from Wheel Mate Performance(Rays,Volk,Gram Wheels). The race car functionality allows for full stud engagement and the open end lets you use extended race wheel studs. The knurled end will also allow you to grip the SR48 Lugs no matter if you’re wearing gloves or not.
The OEM quality construction of the SR48 Lug comes from the use of Cold Forged Chrome Vanadium metal and oversized 60 degree cone seat for better contact on your wheels. The available colors of Titanium, Burned Blue, Pink, Chrome Neon, Red, Blue, and Black, give the SR48 the show car class looks your car requires.
-60 degrees taper seat
-M12×1.25 or M12×1.50 thread pitch
-Cold Forged Chrome Vanadium Construction
-Finishes: Chrome, Black, Titanium, Red, Orange Chrome Neon, Purple Burning Blue, and Blue
-20 48mm open end lug nut set
-comes with 1 3/4″ & 13/16″ dual hex adapter
Available colors:
Black-Titanium-Chrome Neon*-Purple-Red-Blue-Silver Pearl-Burned Blue Neon*-Pink-Yellow
Light-weight, racing style lug nuts at an affordable price, that’s what the Muteki Open Ended Lug Nuts are about from Wheel Mate Performance(Rays,Volk,Gram Wheels). The cold-forged steel of the Muteki Lug Nut permits it to be smaller, thinner, and lighter than normal steel nuts. Furthermore, the compact size of the Muteki Lug Nut allows it to be used in small diameter wheel holes. The open ended Muteki Lug Nut also allows for longer racing studs and full thread engagement. That, combined with the oversized 60 degree taper seat, ensures that the Muteki Lug Nut will keep your wheel secure. The unique shape of the spline drive will also signify that your wheels will not be removed by a thief passing by.
-M12×1.25 or M12×1.50 thread pitch available
-Cold forged 1008 steel
-Finishes: Chrome, Black, Red, Purple and Blue
-20 spline drive lug nuts set
-Includes a 3/4″ & 13/16″ dual hex adapter
Available colors:
Black-Chrome-Purple-Red-Blue
SPC rear camber kit:
These cams replace the OE camber and to adjustment cams and provide additional camber (±2.0°) and toe (±2.0°) changes. Adjustment slots will need to be elongated using the 85130 rotary file set or equivalent. This is the perfect kit to adjust rear alignment angles for optimum handling and maximize tire life.
BC Racing rear extenders:
The adjuster extenders allow you to make the rear dampening adjustments without removing the rear wheels. By making two small holes in the rear floor the adjuster extension can be passed through the shelf so that the adjustment can be performed from the inside.
Available kits:
Honda
92-95 Civic(rear eye)
92-95 Civic(rear fork)
96-00 Civic(rear fork)
90-97 Accord
98-02 Accord
01-03 Acura CL
99-03 Acura TL
01-05 Civic
02-06 Integra/RSX
00-09 S2000
91-05 NSX
03-07 Accord
03-05 Civic
88-91 Civic/CR-X(rear eye)
06-11 Civic
92-01 Prelude
04-08 Acura TL
06+ Civic Type-R
07-08 Fit
08-12 Accord
09- Acura TSX
96-02 Accord
09- Fit
04-08 Acura TSX
09+ Insight
88-91 Civic/CR-X(rear fork)
97-01 Integra(rear eye)
94-01 Integra(rear fork)
06+ CIVIC TYPE-R
10+ CRZ
73-79 Civic
02-08 Accord Wagon
07-12 RDX AWD
80-83 Civic
12- Civic
96-03 LEGEND
05-10 Odyessy USDM
09- Acura TL FWD/AWD
2013- Accord
Mitsubishi
95-99 Eclipse
96-03 Galant
96-00 Lancer/Virage
02-07 Lancer/Virage
04-07 Lancer Rally Art
94+ FTO
02-07 Evo VII/ VIII/IX
03- GRUNDER
00-05 Eclipse
99-04 Galant
96-01 EVO IV/V/VI
89-94 Eclipse AWD
91-99 3000 GT AWD
91-99 3000 GT FWD
06-12 Eclipse
89-94 Eclipse FWD
92-95 EVO I/II/III
07- COLT PLUS
08- LANCER
08- EVO X
89-91 Galant VR4
03-06 Outlander
90-99 GTO
07- Outlander
Toyota
91-99 Tercel/Starlet
03-08 Corolla/Altis
03-08 Matrix
93-97 Corolla
94-97 Exsior
98-00 Premio
97-01 Camry
92-00 Chaser
00-05 Vios/Echo
02-06 Camry
04- WISH
90-99 MR2
90-99 MR2
86-92 Supra
83-87 Corolla W/spindle
83-87 Corolla W/O Spindle
93-98 Supra
06-11 Yaris
07-11 Camry w/o rear top mounts
07-11 Camry w/rear top mounts
00-05 MR2 Spyder
00-05 MR2 Spyder
00-05 Celica
90-93 Celica AWD
94-99 Celica
89-92 Cressida/Chaser
09-13 Corolla/Altis
86-89 MR2
94-99 CELICA (SUPERSTRUT)
94-99 CELICA(SUPERSTRUT)
90-93 CELICA-FWD
09- COROLLA
93-97 COROLLA SUPERSTRUT
00-05 bB
85-88 CRESSIDA
97~02 CALDINA
99-04 CROWN MAJESTA
00+ CELICA (SUPERSTRUT)
03-08 CROWN
95-05 SOLARA
12- YARIS
01-04 CHASER 4WD
07+ AURIS
99-03 CROWN
12- CAMRY (Exc SE)
92+ CARINA E GTI
08+ AVENSIS
12- CAMRY SE
Nissan
95-99 Maxima
00-06 Sunny
93-up March
91-96 G10
91-94 Sentra
89-94 Skyline R32-GTR
95-98 Skyline R33 GTR
99-02 Skyline R34 GTR
00-03 Maxima
95-99 Sentra
89-94 Silvia 240SX
95-98 Silvia 240SX
89-94 Skyline R32 GTS
95-98 Skyline R33 GTS
03-09 Fairlady Z/350Z
99-02 Skyline R34
90-96 Fairlady Z/300ZX
84-88 S12
02-06 Altima
04-08 Maxima
07-12 Sentra
99-02 Silvia 240SX
07- Altima
09- Maxima
08- Skyline R35 GT-R
09- Fairlady Z/370Z
96~01 STAGEA RB25 AWD
96~01 STAGEA 260RS AWD
01~07 STAGEA 2WD
01~07 STAGEA AWD
99-02 G20
09+ TEANA
91-95 Pulsar GTIR AWD
96-01 STAGEA 2WD
07+ Crossover 370GT-FOUR
10- Juke
99-04 Cedric/Gloria (W/spindle)
95-99 Cedric/Gloria (W/spindle)
07+ 370GT 2WD
85-87 R31 (AUS SPEC) (W/O Spindle)
02-06 Cima(W/spindle)
99-02 Skyline R34
93-97 LAUREL AWD
99-02 Skyline 4WD
10- Juke AWD
Ford
08-11 FOCUS MK2
00-07 FOCUS MK1
05- MUSTANG
94-04 MUSTANG
07+ Mondeo
11- FIESTA
89-95 LASER
12- FOCUS
Subaru
97-01 Impreza WRX
02-07 Impreza WRX
05-07 Impreza STI
05-09 LEGACY
00-04 LEGACY
05-09 OUTBACK
08- WRX
95-99 LEGACY
08- STI
98-02 FORESTER
03-07 FORESTER
08-13 FORESTER
10- LEGACY
10- OUTBACK
11- STI SEDAN
90-94 LEGACY
10-11 EXIGA 4WD
12- BRZ
12- Impreza G4
00-04 OUTBACK
14- FORESTER
Dodge
94-99 Neon
00-05 Neon
03-05 SRT-4
11- 300C
11- 300 SRT-8
05-10 300C
05- 300C AWD
VW
85-99 JETTA Ⅱ
85-99 Golf
99.5-05 Golf IV
99-04 JETTA IV
99-10 NEW BEETLE
99-06 BORA 2WD
95- Vento
06-10 Golf V(GTI,DTI)
98-05 PASSAT
06-09 GOLF V 1.6 (Strut 49.5)
10-13 GOLF VI
06-11 PASSAT
10+ POLO
12- GOLF R (W/O DCC)
09+ SCIROCCO
09- PASSAT CC
04-10 TOUAREG
74-83 Golf
99-05 JETTA IV AWD
99-05 Golf R32 AWD
99-06 BORA AWD
BMW
92-98 3 Series Sedan
94-99 3 Series Coupe/Vert
00-06 3 Series Couple
99-05 3 Series Sedan
06-12 3 Series Couple
85-87 3 SERIES 45MM
95-03 5 SERIES SEDAN
88-92 3 SERIES 51MM
04-09 5 SERIES
96-02 Z3
07-13 120i/130i
03-08 Z4
07-13 3 SERIES
01-06 3 SERIES
06-10 5 SERIES
11- 5 SERIES
07-12 3 SERIES Vert
06-11 3 SERIES
06-10 6 SERIES
00-06 X5
11-12 1 SERIES M COUPE
06-08 Z4 M
95-01 7 SERIES
95-99 3 SERIES COMPACT
95-99 3 SERIES
12- 6 SERIES 650i
89-95 5 SERIES (55mm)
12- 3 SERIES
82-88 5 SERIES
11+ 1 SERIES
02-08 7 SERIES
07-13 3 SERIES (W/O EDC)
13- X1
Mercedes
01-07 C230/C240/C320
07-11 C200
04-11 SLK
08- C63 AMG
03-09 E-CLASS
04-06 E-CLASS WAGON
10- E-CLASS
02-09 E-CLASS SEDAN(Airmatic)
Suzuki
05- SWIFT
11+ SWIFT
Hyundai
03-08 Tiburon
09- GENESIS (Sedan)
10- GENESIS (Coupe)
12- VELOSTER
11- SONATA
11- ELANTRA
10- Tucson
Mazda
98-03 PROTÉGÉ
03-08 MAZDA 6
93-95 RX-7
04-13 MAZDA 3
89-05 Miata / MX5
04-11 RX-8
87-92 RX7
00- Premacy
98- MAZDA 323
89-94 MAZDA 323 GTX
07+ MAZDA 2
89-94 MAZDA 323 GTR
06-10 MAZDA 5
06- MX-5
90-94 323 ASTINA
09-13 MAZDA 6
90-95 COSMO
12- MAZDA 5
12- CX-5
14- Mazda 6
Chevrolet
05-10 COBALT
95-05 CAVALIER
10- CAMARO
09- CRUZE
12- SONIC
10- SPARK
Lexus
99-05 IS-200/IS300
06-12 IS-250
98-05 GS-300
95-00 LS400
93-97 GS-300
01-06 LS430
06-12 IS250/GS350 AWD
90-94 LS400
07- LS460
01-10 SC430
10- IS 250C
97-01 ES300
02-06 ES300
92-00 SC300/400
11- CT200h
13- GS350
Audi
05-13 A3
96-01 A4
02-08 A4
03-08 S4
00-06 TT AWD
99-02 S4
00-06 TT 2WD
08- A4/S5
96-01 A4 AWD
99-05 A6 AWD
07- TT
Mini
02-06 COOPER
07- COOPER
11- Countryman R60
Scion
05-10 TC
04-07 XB
08- X8
11- TC
12- FR-S
Infiniti
91-96 G10
03-07 G35 Coupe
03-06 G35 Sedan
99-02 G20
02-06 Q45 (W/spindle)
06-10 M35/M45 RWD
07-08 G35 V36 Sedan
08-13 G37 Coupe
09-13 G37 Sedan
03-08 FX35/45 AWD/RWD
04-06 G35 AWD
97-01 Q45 (W/O Spindle)
97-01 Q45 (W/ Spindle)
11- M37
09- G37x
07-08 G35x V36
09- FX35 RWD
09- FX35 AWD
06-10 M35 AWD
09-13 G37 Convertible
08- EX35 AWD
08- EX35 RWD
09- FX50S AWD
11- M37 AWD
KIA
10-13 FORTE
11- OPTIMA
Porsche
04-10 Cayenne/S (w/o PASM)
98-05 PORSCHE 996 Turbo
09-12 PORSCHE 997
Dodge
95-99 Neon
00-05 Neon
03-05 SRT-4
06-10 Charger SRT-8
06-10 Charger
08- Challenger
08- Challenger SRT-8
07-12 CALIBER
08-09 CALIBER SRT-4
96-08 VIPER (97.5)
07- Charger AWD
11- Charger
12- Charger SRT-8
13- DART
96-08 VIPER (85.5)
Lotus
02+ ELISE / EXIGE
Pontiac
06-09 SOLSTICE
04-06 GTO
08-09 G8
Volvo
01-09 S60
00-04 S40/V40
05-11 S40
05-11 V50 FWD
98-00 S70
07-12 C30
00-07 V70 FWD
08-10 V70
Jeep
05-10 CHEROKEE SRT8 AWD
Cadillac
08-13 CTS
BC Racing Coilovers installed on 1st Generation FX
2nd Generation FX
How much for set of black lugs
