2009+ Infiniti FX35/FX37/FX50/QX70 Camber Kit. Front and Rear Control Arms
Ed@TunerStore
www.tuner-store.com
iS VIP
2004 Infiniti FX35 Supercharged
Car alignment is absolutely crucial when modifying your car. Alignment can effect every aspect of your driving experience, from straight line stability, under-steer, over steer, acceleration, braking and tire wear. Although stock components allow slight alignments from the stock suspension settings, they often are not able to properly align the car after the suspension has been modified. From the factory, most cars are set to have under-steer and for optimum tire wear at stock height; under-steer is often undesired from a performance standpoint and almost all performance driven applications are lowered.
Megan Racing Inc. has developed reinforced and adjustable control arms to accommodate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powder-coated with a 3-Stage process to ensure durability and protection against the elements.
Alignment is crucial to the handling of your vehicle. Remembering that the only thing that touches the ground is your "Contact Patch" of your tires you have to make sure that your tires and wheels are doing exactly what you want. With this you must make sure you have the proper camber, caster and toe as well as make sure they are all working together and not against each other.
SPECIFICATIONS & FEATURES:
- Constructed of Steel Alloy for Lightweight yet Durable performance.
- Hard Rubber bushings for a more direct feel and driving experience.
- Easy to access turnbuckle-style adjustment.
- Can be adjusted without removing from the vehicle.
- Eliminates Premature Tire Wear while improving handling and stability
-Sold in pairs
Will fit 2009+ Infiniti FX35/FX37/FX50/QX70
Here is a link to purchase:
Megan Racing Front Rear Camber Arms Kit for 2009-2020 Infiniti FX35 FX37 FX50 QX70
I've been waiting for this solution for months and when I finally found out about it yesterday I was super excited and ready to buy. I found some good prices online, but luckily I didn't pull the trigger. Zebra happened to post this today and I saw it. He gave me a great deal! Purchased and looking forward to getting them quickly. Don't hesitate guys, grab these from Zebra!
If you want your lowered 2nd Gen alignment to be within factory specs again, you'll need them.
If the camber wears on your tires are negligible, you may want to weight the cost and life of the tires over the price on the front and rear arms.
Such a long time coming on these. Cant wait to see your results, . . and more lowered 2nd gens
Wait a minute! Is this what I think it is?! The solution for the issues associated with excessive wear on tires when lowered? If so, I'm definitely down for a set for the front and rears! Awesome work!
