V.Products 2009+ Infiniti FX35/FX37/FX50/QX70 Camber Kit. Front and Rear Control Arms
Discussion in 'Vendors' started by Ed@TunerStore, May 19, 2016.
  1. Ed@TunerStore
    Ed@TunerStore www.tuner-store.com iS VIP
    11,090
    542
    Miami
    Car:
    2004 Infiniti FX35 Supercharged
    Car alignment is absolutely crucial when modifying your car. Alignment can effect every aspect of your driving experience, from straight line stability, under-steer, over steer, acceleration, braking and tire wear. Although stock components allow slight alignments from the stock suspension settings, they often are not able to properly align the car after the suspension has been modified. From the factory, most cars are set to have under-steer and for optimum tire wear at stock height; under-steer is often undesired from a performance standpoint and almost all performance driven applications are lowered.
    Megan Racing Inc. has developed reinforced and adjustable control arms to accommodate the needs of the aggressive and performance oriented tuner. Being constructed of a Lightweight Steel-Alloy which is able to withstand the stresses of extreme competition, these arms are powder-coated with a 3-Stage process to ensure durability and protection against the elements.
    Alignment is crucial to the handling of your vehicle. Remembering that the only thing that touches the ground is your "Contact Patch" of your tires you have to make sure that your tires and wheels are doing exactly what you want. With this you must make sure you have the proper camber, caster and toe as well as make sure they are all working together and not against each other.
    SPECIFICATIONS & FEATURES:
    - Constructed of Steel Alloy for Lightweight yet Durable performance.
    - Hard Rubber bushings for a more direct feel and driving experience.
    - Easy to access turnbuckle-style adjustment.
    - Can be adjusted without removing from the vehicle.
    - Eliminates Premature Tire Wear while improving handling and stability
    -Sold in pairs
    Will fit 2009+ Infiniti FX35/FX37/FX50/QX70
    Please email me for pricing! Thanks for Looking!
  2. meme405
    meme405 Premium Member Premium
    3,217
    206
    Vancouver, BC
    Car:
    2008 FX35
    Zebra is on it. Sweet, a must have for every 2nd gen owner.
    Ed@TunerStore likes this.
  3. PEEJ
    PEEJ Weeeeeeee!!!
    1,429
    315
    Colorado Springs, CO
    Car:
    2014 QX70S 5.0
    Name:
    Patrick
    PM me, Zebra. I want to buy a set.
    FXThreeSeven likes this.
  4. OP
    Ed@TunerStore
    11,090
    542
    Miami
    Car:
    PM'd!
  5. PEEJ
    PEEJ Weeeeeeee!!!
    1,429
    315
    Car:
    2014 QX70S 5.0
    Name:
    Patrick
    Btw, for anyone considering these, zebra's price is $150 less than ordering directly from the meganracing site.
    Luis Gutierrez and Ed@TunerStore like this.
  6. Eothain
    Eothain Rider of Rohan Premium
    854
    95
    Nashville, TN
    Car:
    2011 FX35 AWD
    I've been waiting for this solution for months and when I finally found out about it yesterday I was super excited and ready to buy. I found some good prices online, but luckily I didn't pull the trigger. Zebra happened to post this today and I saw it. He gave me a great deal! Purchased and looking forward to getting them quickly. Don't hesitate guys, grab these from Zebra!
  7. roughx021
    roughx021 Member
    221
    4
    Stony Brook
    Car:
    2010 FX35
    Is this for the front or rear tires?
  8. PEEJ
    PEEJ Weeeeeeee!!!
    1,429
    315
    Car:
    2014 QX70S 5.0
    Name:
    Patrick
    It's for BOTH!
  9. Eothain
    854
    95
    Nashville, TN
    Car:
    2011 FX35 AWD
    The first picture is the front arm and the second is the rear.
  10. roughx021
    roughx021 Member
    221
    4
    Stony Brook
    Car:
    2010 FX35
    Ok thanx. Being that Im only on H&R springs, do I need front and rear or just rear?
  11. la_fx35
    la_fx35 Staff Moderator
    20,233
    1,139
    Chicago
    Car:
    2003 FX45
    Name:
    Andy
    If you want your lowered 2nd Gen alignment to be within factory specs again, you'll need them.
    If the camber wears on your tires are negligible, you may want to weight the cost and life of the tires over the price on the front and rear arms.
  12. 1sq1
    1sq1 Member
    53
    11
    San Diego, Ca.
    Car:
    2010 FX35 RWD Obsidian black
    Zebra, can you pls pm for front and rear control arms. Thanks.
  13. gto
    gto Track Ready Moderator
    16,673
    656
    Los Angeles, CA
    Car:
    05 FX35 RWD
    Such a long time coming on these. Cant wait to see your results, . . and more lowered 2nd gens
  14. OP
    Ed@TunerStore
    11,090
    542
    Miami
    Car:
    PM'd
  15. Athlon
    Athlon Member
    67
    3
    Austin, TX
    Car:
    09 FX35
    Wait a minute! Is this what I think it is?! The solution for the issues associated with excessive wear on tires when lowered? If so, I'm definitely down for a set for the front and rears! Awesome work!
  16. Eothain
    854
    95
    Nashville, TN
    Car:
    2011 FX35 AWD
    Athlon likes this.
  17. santiagodraco
    santiagodraco Member
    451
    22
    Austin, TX
    Car:
    2010 FX 50s
    Sent you a PM Zebra! Probably start with the rears... but this is great news. Made my day.
  18. OP
    Ed@TunerStore
    11,090
    542
    Miami
    Car:
    PM replied. Thank you!
  19. mm2k4
    mm2k4 Member
    7
    Canada
    Car:
    2012 FX35
    how much for front and rear shipped to 98230?
  20. OP
    Ed@TunerStore
    11,090
    542
    Miami
    Car:
    PM'd
