...quite a similar problem but...
if the wheels are swapped the *.* remaines in the same position, what is reading the tpms output?
Any sensors near the wheel?
https://www.infinitiscene.com/search/1/?q=16534-Reprogram-Your-TPMS-DIY...and they can self learn so you don't need them programed by the dealer if you do it yourself with the help of the DIY article somewhere on this site. Sorry, don't have the time to look it up right now
Sensors aren't location specific, you can swap tires and the sensors will still show as the same location.
It indicates which tire has what pressure. He meant that you can move you driver front wheel to any other location and the computer will read the psi at that new location without having to reprogram it.Didnt know that. Thanx
... whitch makes this system a bit pointless. You can see that one tyre is starting to go flat but you dont know whitch one![]()
