I would like to know if anyone knows where I could order the sideview mirrors with the turn signals on them .
They're all over Ebay. Be wary though, the set I ordered and had painted was the wrong color (from seller "nabobery" - FRAUD!!) and I had to repaint them when they arrived. The install process is no joke either.
Here's them on my FX - https://www.infinitiscene.com/searc...rom-Marek-Extreme-Designz?p=433493#post433493
Where did you get those headlights and those leds next to your fog lights
You can always attempt to make your own covers and retrofit turn signals injust saying
Yes! Precisely what I did with my G37. Even more of a bitch job though with the precise dremelling needed!
Those are Hella DRL strips from iJDMtoy. They fit perfect and have had them on for 2 years with no problem. Bright as all hell too!
http://store.ijdmtoy.com/Hella-LEDayline-LED-Daytime-Running-Lights-DRL-p/led_ddl_sku78.htm
Headlights are custom painted and dual-orbed by http://oneightynyc.com
Yep, that's where I got mine, but beware, that seller is 100% fraud, like I said. I'd definitely purchase them elsewhere.
Where do you think I should put those LED strips lights on my QX?
[/URL][/IMG]![]()
Nice G37S! My friend just got a 2010 g37XS in gray last tuesday!
The first set I made using Audi mirror turn signals. They required way too much work, heating up, bending to shape. There is a whole DIY write up in my garage.
Then I came across turn signals for Volvo S40 and those fit almost perfect without any heating up, and bending them to fit. The process of molding the opening took time but I like those much better.
And yes wrapped the mirrors in CF to match the roof and lower rear bumper piece.
So badass. You did what I did on my G then, just dremelled out the pattern carefully on OEM covers? The biggest PITA was wiring through that pivot head with all the other power wires. Ugh I still have nightmares about it all. So much work for such a relatively simple mod.
