carguy75
- alpharetta,ga
This morning I finally got around to changing both of the engine drive belts on FX45. However, I checked the FSM first before I did the job and it mentions only removing the the front air scoop over the radiator only to gain access to the top drive belt. But, I had to remove the fan shroud and unhook the top radiator hose as well, because the upper radiator hose had to be moved so that the fan shroud could be removed. Did anyone change out their drive belts without removing the fan shroud? If not, it looks the FSM left out a couple key steps in the belt replacement instructions. FYI, is you are planning on changing both drive belts at the same time do not install the top belt first, because it sits in front of the lower belt on the flywheel pulley, which mean you will have to remove it again when you go underneath the FX to change the lower belt. I learned that the hard way,noob mistake:rotfl:
