What is the offset on the rear wheel? Can't wait to see them installed.
Haha i was wondering when someone would ask me this question :smile (2): Being a wheel/tyre guy and from a bussines point of view i would normally not tell these things. And i won't here in the netherlands. I am called on a daily basis by people asking me what the maximum specs would be for their car so they can order the wheels for 50 USD cheaper on the internet. They even get mad when i tell them i will not give any details unless they order the wheels and have made a down payment. You have to protect yourself nowadays when having your own shop.
But when me still being a big fan of this forum and helped me out a lot with my FX build i'm not going to play hardball here :smile (2):
I calculated from my prior specs:
Front 10,5 x 22 offset +40 +/+ 10mm spacers
Rear 10,5 x 22 offset +40 +/+ 15mm spacers
At the front i took the exact same messurments as i had but now without the spacer.
The rear i calculated howmuch the old setup came outwards. For me that was the maximum. The i check in wich offset i would get when wanting the 12 inch width. I got my numbers and messured if the body would have enough room inwards messured with my old gianelle wheels.
My new setup will be more inwards them oem is but it fits.
So new setup:
Front: 10,5 x 22 offset +30
Rear: 12 x 22 offset +45
Today i wanted to put one under the car to see for myself and make some pics as i cannot wait that long either. But the weather is bad so i will have to do that another time. Need to lower the car more probably either and engine is out so the perfect stance will probably come on a later stage, but at least show you guys some pics :good:
