My seat doesn't move!!!!
rcruz
Providence, RI
2008 fx35
So my drivers seat does not move up and down to adjust to drive. I took it to Infiniti and they said it would be 1350 to be replaced * pause ....... I almost died because that is way too expensive. After some research they said that this problem usually occurs. Any help with this? Anyone have an extra seat track lying around in their garage lol?
Lmao "pause"
Sent from my SGH-T999 2
I had similar problem with the up down switch not working.In my case something had fallen into the switch physically keeping it from operating.I took it apart and removed a small watch battery that had found its way into the switch assy.Worked fine after that.
You could also check the seat motors by "lightly" tapping the motor with an small hammer while pressing the seat switch at the same time. If the seat then moves then you may have a bad seat motor.
Might want to open up the switch and clean the contacts. I beleive thier is a video on how to do it on a g35 which is very similiar. If not you can get a new switch for about $70 and very simple to replace.
