- Miami
- 2004 Infiniti FX35 Supercharged
No extended wiring needed, its long enough to relocate the screen below. You just need to cut all the plastic inside to fit the aftermarket unit and oem screen below.
That looks great, I am extremely interested in doing the same in dash install to my 2005 fx35. I am somewhat confident in my cosmetic abilities, but I do not have enough knowledge about the wiring process. Is there any information you could share about how to wire an aftermarket 2 din in dash unit into an FX?
Is the wiring harness/the colors of the wires similar to standard domestic wiring harnesses?
Thanks for any assistance you can provide and, again, great job on your custom install.
She turned out amazing! Fantastic work , very impressive!
where did you get that shit boot thing? can i get one for my fx too ???
I ordered the "SHIT":rotfl: boot thing at Perry Infiniti
You will need Metra 70-7551 to wire an aftermarket unit. Mine is hardwired, since I removed all Bose components
Thanks
This will connect the speakers/amplifier and power to an aftermarket unit. The OEM screen has a separate connector, you just need to relocate the screen.
Ok thanks, I ordered the harness, do I need the antenna adapter too? Also, did you custom cut the bezel around the clock where you mounted the stock screen? and how did you trim it around the edges? Hopefully I will be able to finish the install next week and post pics
