Silviu
- Boca Raton
Does anyone know why the light of airbag is blinking?
Did you do any modding/fixing/electrical work? Changed incabin filter, removed the seats, etc...anything that might have been in proximity to one of the yellow plugs for an airbag?my airbag light blinks all the time, even after a reset (couple daysnpass and starts again). What part needs to
be changed?
Yep as AeroBFA, is right on. Just need check the connection. Once the airbag light is lit it will not turn off simply by disconnect and reconnect the connector. It needs to be reset to turn off the light.thanks guys and they did change my front seatbelts too, and la fx35 the last part i didnt get it, when the light is lit i have to unpug ad replug?
I had an intermittent short in the driver seat adjustment for years, occasionally the airbag light would come on, but I didn’t connect the dots. You can reset it a few times yourself.my airbag light blinks all the time, even after a reset (couple daysnpass and starts again). What part needs to
be changed?
