im getting random flashes of the brake, vdc, slip and abs lights.. Brakes should be fine, hopefully its just low fluid.. Time to investigate..
Might be my old age, but didn't you trade in your Fx for that shiny M machine?
im never going to sell my FX, i bought the shiny m3 as an additional car. On another note my brake pads are fine, the brake fluid level is in between min and max.. Im lostMight be my old age, but didn't you trade in your Fx for that shiny M machine?
Found out I need to change wheel bearing on driver side front wheel... Any one did this before? How hard is this?
strut bearings? maybe a suspension bolt or bushing is loose
Brake pad or wheel bearing?
Hmmm, first time I heard about this. Just curious, while this is happening, did the speed actually drastically dropped according to the speedo or it is just the speedo not reading accurately?
Just got one replaced yesterday. Was pretty bad almost locked up on me on the highway. Replaced it with a Timken assembly. Did you do yours yet?Found out I need to change wheel bearing on driver side front wheel... Any one did this before? How hard is this?
