- Portland, OR
Put your money where your mouth is
http://www.globalautoshop.com/accessories/automotive/infiniti_index.html
HA! :tongue (2):
I think it's legit. But it's a simple aluminum tube, brackets and MAF adapter.
Why don't you try it?
for the 2nd generations out there want quick free horsepower. Take out your fiilters and the plastic that holds the filters in. Your engine will growl +10-15hp..
Installed preoil drop in K&N air filter about 6-7 months ago, here is the symtom starting 3-4 days ago. Idle drop every once a while. car loss power while driving. can be dangerous if it was in high traffic situation. lucky my wife was able to pull over to the side of the road. wait few minute and it would start going again. This happen random so it would drive nornal and it would just happen all the suddent. also MPG would decrease. MPG go down to 16mpg on the trip info screen. Took it to the dealer, service result was Air flow meter sensor damage cause by oil from K&N filter. Cost to replace sensor by dealer? $800 and some change. decide to do it myself... got used one from JY for from 350Z same part #. 350Z sensor cost me $25. sensor replaced and stock filter put back in.. problem gone. MPG now back to 20 also. keep my finger cross for now. any one experience this? comment.....
sprtfx, I do have the K&N air filter, but I do not have the loss of power or idle drop... I am however getting horrid mpg which has been declining over the last year or 2... Which is about when I put the K&N in. My mph has gone down to 11-12mpg this winter. Last winter was probably 15-16mpg. I would like to change the Air Flor Meter Sensor regardless, to see if it will cure the problem. I also have the gas gauge problem, which I tend to fix tomorrow. Where is the Air Flow Meter Senor located? Is it easy to switch. I know its a lot to ask but a picture of it would be FANTASTIC!
Cheers!
Cheers!
