2003 - 2008 Infiniti FX35 FX45 Kido Racing Coilover Group Buy LIVE
2003 – 2008 Infiniti FX35 FX45 Coilover Group Buy
1) Chedman13 (Chicago, IL) 12KG Front / 12KG Rear
2) la_fx35 (Chicago, IL) 10KG Front / 12KG Rear
3) FX45Chicago (Chicago, IL) 10KG Front / 12KG Rear
4) Slamming45 (Chicago, IL) 10KG Front / 12KG Rear
5) UNVMYFX (Murfreesboro, TN) 10KG Front / 12KG Rear
6) Buddhist_fist (Vancouver BC, Canada) 10KG Front / 12KG Rear
7) JLee (SF Bay Area, CA)
8) Jcasanova (Houston, TX) 10KG Front / 12KG Rear
9) Logan (Seattle, WA) 12KG Front / 12KG Rear
10)
11)
12)
13)
14)
15)
Most manufactures recommend inspecting and or replacing shocks and struts around the 60K interval, some change at 80-100k and some simply dont.
Is it possible to change my order to different spring rates?
Yes, your order isn't sent to Kido yet because I haven't received your PayPal info, unless it got lost some how.
Let me know what spring rate and send me your PayPal info as well.
how long is this gb going for? im debating if i should buy some and use it in the future when my oems go out..
Why not buy and use them right away? It will be night and day difference from OEM to coils.
Sent from my HTC_Amaze_4G
dont like throwing things away when still good :P. what difference would i notice? Do oem springs usually need to be replaced? if so how long? Trying to figure out the price difference.. between new oem setup and these sexy things
Forgot to post this information, after payment is received by Kido, approximate shipping and handling times:
1 business day to prepare kit for shipping
3-5 business days for shipping time, depending on location.
So approximately 1 week after payment.
Note, you will get full tracking number.
Are these shipped out right away or do we have to wait until the group buy ends?
---------- Post added at 10:02 AM ---------- Previous post was at 09:57 AM ----------
Note that all custom spring rates will be valved properly and with proper oil weight. E.g. 10KG, Kido use 5W damper/spring synthetic oil. 12KG, Kido uses 10W.
1) Chedman13 (Chicago, IL) 12KG Front / 12KG Rear - PAID
2) la_fx35 (Chicago, IL) 10KG Front / 12KG Rear - PAID
3) FX45Chicago (Chicago, IL) 10KG Front / 12KG Rear - PAID
4) Slamming45 (Chicago, IL) 10KG Front / 12KG Rear - PAID
5) UNVMYFX (Murfreesboro, TN) 10KG Front / 12KG Rear - PAID
6) Buddhist_fist (Vancouver BC, Canada) spring rate to be determined - awaiting PayPal e-mail and spring rate decision
7) JLee (SF Bay Area, CA) 10KG Front / 12KG Rear - invoice sent
8) Jcasanova (Houston, TX) 10KG Front / 12KG Rear - invoice sent
9) Logan (Seattle, WA) 12KG Front / 12KG Rear - invoice to be sent
10)
11)
12)
13)
14)
15)
Most springs will live the life of the car. Struts and shocks will need to be replaced. Most FXer here have their struts and shocks replaced around 60K miles for wear and tare.
Im wondering if these will lower my ride or just make the ride firmer because im getting close to the 60 and will probaly need to get some?
These are height ad dampening adjustable. So you can lower/raise and adjust the firmness to your liking.
Sweet and the Cream is 8 if I read that right? if so I need to add my name and paypal info
For street setting, Kido highly recommends Front: 10KG / Rear: 12KG spring rates and shocks valved to these spring rates. Your 2003 FX35 AWD is:
2003-2008 FX35 AWD – 4,204 lbs (curb weight) 53% (front) /47% (rear) weight distribution
So from feedback from FX riders in Taiwan and also from the number (curb weight and distribution), 10KG/12KG is the way to go for a street setting. You can then adjust the ride comfort level with the shocks to as firm as you want or as soft as you want. You can also have stock ride height, higher, or lower. It is up to you. All I need is your paypal e-mail (PM or e-mail it to me) and Kido will send you an invoice. You should get your coilovers in around 1 week after payment.
I gotcha so once installed on the car you can adjust them easily correct to whatever setting you like right or wrong? What I meant about the Cream was the money 8bils right or is it more?
