View attachment 249620 ITB06-026a Service Campaign View attachment 249621
2003–2006 INFINITI FX; VOLUNTARY SERVICE CAMPAIGN HEADLAMP ASSEMBLYNissan has determined that on some model Year 2003-2006 Infiniti FX35/45 vehicles, the headlamps fail to comply with certain requirements set forth in Federal Motor Vehicle Safety Standard (FMVSS) No. 108.The standard specifies, among other things, the performance requirements for headlamps in passenger vehicles. One of these requirements specifies the vertical gradient values for headlamps. Another specifies minimum and maximum light intensity of headlamps at certain test points. The headlamps in the vehicles subject to this TSB may not meet these requirements. This means that the headlamp aim may be difficult to adjust. Also, the headlamps may be too bright or too dim when viewed at certain angles. Reduced visibility increases the risk of the vehicle being involved in a crash. Increased brightness and improper aiming of headlamps can increase glare. To correct this condition, Nissan is conducting a Voluntary Recall Campaign to replace the existing headlamps with new and compliant lamps free of charge. |
