dmindc
- Northern Virginia
So I ended up getting an unrepairable hole in the side of one of my tires. Of course with AWD I'm supposed to change out all 4 tires...or am I?? I've got 65k on the tires, but rotate them religiously and the tread isn't too bad (40%-ish). I could probably get through the winter no problem.
Can I get away with only buying 2 tires and not messing up the transmission? Am I taking a chance by doing so?
Should I be grateful that I got 65k out of the set and just step up and buy 4 new ones? If I do the same Bridgestone Dueler H/P 265/50R20 tires are $1400 out the door. Worth another 65k or buy something less expensive?
2009 FX35 AWD
Thanks in advance!
2009 FX35 AWD
Thanks in advance!
