The Random Question Thread
I need a new dash
Part 68200-CG06A
Dealer here is $1000
Infinitipartsusa is 1100 after shipping
Anywhere to buy cheaper?
Are they brembo or standard size rotors?
For 200-2005 350z standard rotor size for were:
front:11.7" x 0.95"
rear 11.5" x 0.63".
Brembo
front: 12.8" x 1.18"
rear: 12.7" x 0.87"
I believe they should fit without any modifications or brackets since the Z and FX share the same exact platform.
front:11.7" x 0.95"
rear 11.5" x 0.63".
Brembo
rear: 12.7" x 0.87"
non brembo and im pretty sure brembo is not a straight bolt on and wont fit
---------- Post added at 01:01 AM ---------- Previous post was at 12:17 AM ----------
so what i see from the chart, the 350z rotors are a little thinner and smaller in diameter
2005 350z
[Dead Link Removed]
2004 fx35
[Dead Link Removed]
What is the correct tint percentage to run on my front windows sothey will match the factory tinting on the back windows on my 11 FX35?
I remember someone saying it was like 18% or something kinda random. I wonder if there's somewhere you can take it and they can measure with one of those tint readers.
Ok. I have 30% on the front now and I want to try and matchy-matchy. I guess 20% will be as close as possible.
Hey all! Quick question. I've been searching and haven't found any aftermarket tail lights for the '13 Fx37. Are there any? If not, will the Fx35-compatible tail lights fit?
(forgive me if this has been covered already)
FX35/37 are exactly the same from 2009 and up.
---------- Post added at 08:04 PM ---------- Previous post was at 08:03 PM ----------
I have 18% and it's slightly lighter. If I had a do over I would do 15 to match perfect.
Hmmmmm ok. Thanks.
Oh sweet! I knew some stuff was interchangeable, but wasn't aware that they were exactly the same. That's like my 370z. From '09 to '12 they were exactly the same. In '13 they only changed the nose, otherwise the rest is interchangeable.
Much obliged for for the information. :smile (2):
Has anyone installed the bypass kit from "car kit company"? Is it legit and works nicely?
So I did the right thing last weekend and handed over my FX keys to my gf after drinking. In that 10 minute drive in Queens she somehow bent my right exhaust pipe. It is now sitting a little lower than usual and to the right of the correct position. Do I bend it back or have it properly fixed?
(PS she drives a civic with a back up cam usually, guess she didn't notice the tree I was parked next to.... -_-)
Xylex,
I installed the bypass kit on my 12FX and it works as described. You can do the DIY mod if you don't mind cutting/removing wires. One of the main advantages of Car Kit's system is that it is reversible and it won't show up in any service diagnostics. It's worth the money..get one.
