The Random Question Thread
No don't shave due to the fact you might shave off the pins that guide/hold the emblem in place. Simply use a heat gun and heat up the two tab points and push on the pin with a handle of a screwdriver.
Ahh, good point :top:
okay so I installed the ichiba spacers 27mm back and 25mm front. It looks incredible! I love the look but.... the steering wheel shakes a lot at 40ish mph to like 65mph. I didnt wanna go faster than that on the highway because I thought wheels were gonna fall off lol. I even got an alignment done after I got the spacers installed. It still shakes a lot. Any help?
Retorque your spacers maybe they are loose.
I just have to make them tighter right? or would I need a torque rench and torque it to a specific lbs or something?
The shaking just started as soon as I put the spacers on so I am guessing it has to do with the spacers.
80lbs should do it, get a torque wrench! harborfreight.com get a 1/2 inch head
Instead of just tightening what is probably already somewhat tight, loosen them and re-seat them making sure they're flat. Be sure to tighten them incrementally in a star pattern. I know this is a little elementary, but more important than a specific torque value.
^Good advice.
Didn't know where to put this, but I washed my fx today and I noticed that on my trim on the rear passenger side has a wrinkle on it as if its vinyl. Do any of yall have this??
Sent from my HTC_Amaze_4G
I have a little one and some others do too. There was a discussion somewhere about it. The discussion ties in with the window molding cracks.
There was a discussion a while ago about some people actually having chrome trim under there. That does to be an overlay of some sort. Give it a tug on a corner and see what's under there.
Need some confirmation about some fluids
Gear Motul GEARBOX 80W-90 (3 litres )http://nextmod.com/webstore/index.php?dispatch=products.view&product_id=30442
power steering fluid (One bottle enough fo flush multiple times? )
transfer case (1 litre)
Which one should i use? i know manual says atf or dexron III. which would would be better tho?
Motul MULTI ATF http://nextmod.com/webstore/index.php?dispatch=products.view&product_id=30445
or
Motul DEXRON III http://nextmod.com/webstore/index.php?dispatch=products.view&product_id=30446
