The Random Question Thread
The spacers you are asking about are DRM spacers (as opposed to DRS) and yes they are available from most makers for our rides, H&R, Ichiba etc.
I like the chicks part, Lol!!!
---------- Post added at 09:11 PM ---------- Previous post was at 08:53 PM ----------
I actually found them on evilbay, I mean ebay lol! Good price and they are centric spacers so I should'nt have any problems with them (I hope.) I cant wait either to get that flush look with the stock 20" inch rims.
Actually that auction is correct, but its the wrong picture. I run H&R 25mm spacers on my OEM 20"s and those are the correct ones you want, but they just have the wrong picture. THE DRS are the ones where you replace the longer studs and DRM come with studs already. I just checked my H&R box and this auction is the one you want: H&R # 5065662. Remember, they are sold in pairs usually, so you will need to buy two boxes.
Can someone please help me I'm looking for a direct bolt on spacer I've seen them but can't find them anywhere. I'm looking for the spacer that has new studs already welded or w.e on it for direct bolt on. It bolts on your oem studs and has 5 new studs where you can put your wheel on.
Hey guys Im gonna be buying the side door mirror covers with the blinkers on them and wanted to know if anyone knows how to wire it up so that the turn signals on them work or if there is a DIY thread on here for it? Unfortunately even though they are brand new they dont come with instructions. Or should I bring it to a shop and pay for someone to wire it up for me???
you have shave off the melted plastic tab on the back on the center cap and then pry it off.
Yes all first gen rear bumper are the same.
No don't shave due to the fact you might shave off the pins that guide/hold the emblem in place. Simply use a heat gun and heat up the two tab points and push on the pin with a handle of a screwdriver.
