1) Aaron has maps for pretty much anything, especially a FX35 since the 350Z works very well on them and there are tons of maps for 350z.
2) Having a base map with NO mods factored in is the map you'll want from what it sounds. If you add a Z tube, no need for another map. When you add a full intake, that's when you'll want another map, but not necessary. Reason is that a full intake can make the engine run a little lean or rich and it will be mapped for that via air/fuel ratios. Adding a z tube won't effect that just increase flow (more hp).
Makes sense?
Makes sense?
Thanks Ed, I've just gotten back from a vacation. Will give Aaron a call sometime soon.
However, I have another question...
I look around and people talking about Stillen z-tube Intake kit to improve performance a bit.
I question is... should I leave my car at stock, no mods or install that intake kit then install unichip on top of it?
I'm thinking if Aaron has a map for no mods that can performs as well as a map for Stillen z-tube intake, then why I should waste money for the intake kit anyway. Is it right?
