In my case, I'm replacing the BOSE subwoofer with amp (same fitment over the spare tire). FX is just running DieHard Gold 640cc battery and should be fine.
Fun project, you should take it on if you are bored in TX.
Just a note soon, if you are planning on putting that where the stock sub goes, remember that you will need some area in the middle as well as a hole to be able to use the stock securing method. Unless you have some sort of other way of securing it...
Why wouldn't it? His rolling diameter is still the same (or close enough to use the spare to limp to a tire shop). Its a BBK that will prevent the spare from being used.
@soon, I saw those two bolts but didn't put 2&2 together. Thats a great idea to maximize space as well. :good:
