Dtrl/turn swap
Well there's no flickering! But that's because I have yet to even get them to light up. Gonna read through about this wire bending some more first.
outer contact groove to the inner groove on both sides of the bulb---
bend up the contact wires---
should look like this when done---
Yeah I did that. Still no light. Right now I'm working on getting the turn signal wires extended, which is not going well either with all that stuff in the way, it can't stretch even with the rubber cover removed.
Release your parking brake off and try them. I had lots of slack after removing wire cover.
Uhhh so I removed my blinker bulb and the whole thing (orange cover) did not come out. Only a small white bulb that fits in the yellow cover. Am I missing something here? See Pictures.
Yellow cover still in housing
---------- Post added at 04:41 PM ---------- Previous post was at 04:30 PM ----------
mine looks completely different actually :confused.:
Those are two different bulbs and two different locations. Looks like you pulled the sidemarker bulb out instead of the blinker.
I got it to work, but just barely stretches. I couldn't remove some wire clip, and thus couldn't route them perfectly above the HID ballast.
I got one side fully trimmed and installed, but it doesn't matter since these LED's don't light up.
---------- Post added at 09:47 PM ---------- Previous post was at 04:01 PM ----------
Little vid that kinda shows the difference between the two placements.
13ef185a.mp4 video by StuLax18 - Photobucket
That's just what I've had in for awhile so what I had available. I will probably switch back but I want to test with the JLC first.
Which bulbs did you replace with LED, both running and turn? Try putting the old bulbs back in to verify that it's not a wiring issue.
