Dtrl/turn swap
MTN FX
Mountain Man
Premium
Big Bear City,Ca.
2004 FX35 AWD
John Green
Drivers Side--remove Air Cleaner Box
Passenger side--Remove Coolant Tank
1) Cut wire sheath off of Turn signal wire---
2) Wire for turn signal exposed and long enough now to reach DTRL opening without splicing wire---
3) Remove weathertite seals---
4) One of the Tabs on DTRL is 6.00mm and turn sig tabs are 8.00mm trim 2.00mm from
from turn signal tab I also trimmed 1.00mm off of one of the DTRL tabs.---
5) The wire conacts on the new CREE DTRL bulbs will have to be moved from the
outer contact groove to the inner groove on both sides of the bulb---
bend up the contact wires---
should look like this when done---
Reinstall weathertite gaskets,test all bulb opperations,reinstall air box and Coolant resevoir---DONE
Finished Pix----
Click on pictures below to see videos--
DTRL MOD :: FXDTRLMod049-MPEG-2-Video.mp4 video by thiniceone - Photobucket
DTRL MOD :: Finished video by thiniceone - Photobucket
I'll post some night shots later:tup::tup:
Finished Pix----
Wow! Great DYI! That's so clever & looks very nice! I didn't like how the original DTRL slot had a second housing for the bulbs so the CREE bulbs wouldn't look as bright but this solves that problem too! Would there be any legal issues (as in it's against the law to...) with this mod??
Shouldn't be any legal issues at all as a matter of fact the new location for the turn signal makes them even more visible from a wider angle.
---------- Post added at 08:18 PM ---------- Previous post was at 08:12 PM ----------
My only concern is when I'm driving in heavy fog the added light may reflect back at me. If this proves to be an issue I will probably install a switch to kill the DTRL lights.
Excellent DIY! This clarifies the "how and why" and should help many of the post GB purchasers through the install phase.....
Problem!!!!
Houston we have a problem. I went for a test drive to try out new lights and after a 10 minute drive when I pulled into my driveway one of the new CREE bulbs started flickering. I pulled the bulb and made sure connection was good and swapped sides and problem persisted.
see video-----
DTRL MOD :: FXDTRLMod052.mp4 video by thiniceone - Photobucket
DTRL MOD :: FXDTRLMod053.mp4 video by thiniceone - Photobucket
So I pulled both bulbs and put the OE DTRL in the new spot not as bright but still better than the previous location. I hope they can work this out.
FYI these bulbs run very hot.
pics of OE bulbs in new location----
MTN, you think the flicker could be caused by the contact wires that had to be moved over? Can you somehow bypass that connection with a couple lengths of wire or something to test the bulb itself?
I tried moving the position of the wires and swaped to other side connector with no difference, Also when the problem started the light was working fine and I saw it change.
Also this is the same thing that happened to Jeff with the 912
mtnfx and tchuck, sorry merging into this thread with this question, can you guys please look at my thread?, posted a new vid today, and tell me if my outter tie rod is bad.. Thank you
///12929
///12929
Bro, I look at every thread. I didn't reply to yours because I don't have an answer for you. I've never seen a tie rod make a sound like that. :dontknow:
---------- Post added at 11:58 PM ---------- Previous post was at 11:46 PM ----------
I'm wondering whether the contact wires are completely intact after bending them over, installing them into the socket, super-heating them, and then bouncing them around in the headlight assembly. JLC says they test each bulb, and it worked when you installed it initially. That said, heat and those bent contact wires seem like the obvious/easy culprits...
They worked fine for 10 minutes. Jeff had the same issue with his reverse bulb.
