- Atlanta, GA
- 2007 FX35
Are you referring to the Roberuta cup kit? That should just sit right on top of your coilover and give you a little lift for speed bumps and curbs. It shouldn't effect your normal drive.
How would airbags not give you side to side stability? There's still a strut in there and you should still have damping. The airbag shouldn't be subject to much lateral load. I've always thought that air ride systems rode horribly, but mostly because of the way air springs work and damping (lower you go, the softer it is), not because there wasn't lateral support although I've heard they've gotten much better.
Guys i Triple checked it with the manufacture and it seems that you cannot drive Both the Drop or Lift kit i both heights continously.
I don't understand though cause one set is continously empty and the other one continously full.
At a certain point i talked to a tech guy in germany and said it could but eventually talking trough the importer here who spoke with the boss it couldn't.
Pitty though.......
The is another system called Roberuta from Japan who does the same.....but it think with air.....but no Bag more like a sleeved metal piston on air.
Thing with air is IMO you just do not have that side way stability what a spring gives you. Think of skippy ball and you sitting on it........if you driven both like i did you know what i mean..........
Bert little question.......are your front wheel wells out on these pics......
