Make sure you're not confusing the extension of the wheel vs the wheel/tire assembly.. While the wheel might stick out a lot compared to stock, the entire assembly might only move half that value...
Check your specks with this site: http://www.rimsntires.com/specs.jsp
That helps, thanks. The guy at Inland Wheel I spoke to said he recalculated the offset and that a 40 offset would work best, which he said would make it about flush with the fenders.
Comparing 265/50/20x8 ET50 and 285/40/22x10.5 ET40 I get:
Suspension clearance: Same
Fender clearance: Package extends 20mm (0.8") farther
Wheelwells: Will fill out wheelwell by extra 7mm (acceptable for most cars)
I may want the wheels to tuck under just a hair, but not sure if a slightly higher offset would still work?
Comparing 265/50/20x8 ET50 and 285/40/22x10.5 ET45 I get:
Suspension clearance: Package is 5mm (0.2") closer to suspension/brakes. Acceptable for most cars.
Fender clearance: Package extends 15mm (0.6") farther
