ok, i just was unaware that the gps cuts out while using the system. That kinda seems like a pain too.
So if you're driving along with a route programmed in, and you want to scroll through your ipod without the car being stopped, you hit the switch on, correct? and when you do, you will lose where you are on the map because the gps is disabled? seems there would be a way around that. if not, whats your overall experience with using the bypass module? pros and cons
