Talk about spinning mass at the wheel, I think Andrew has the lightest 22s setup. I couldn't believe it when I lift the wheel. It feels like nothing. The Rays lug nuts is so freakn' light too. The guys at Discount Tire jokingly commented on whether the Rays lug nuts can hold such a big wheel.
Can either Andrew post the exact location of this Discount Tire? I'm having epic failures with Chicagoland wheel balancers, even if they have the latest Hunter Roadforce machines.
I just mounted the summers on my BMW, which I think are 16's -- felt like I could throw them 100 yards.
Are discount tires with not scratching stuff,
do they have the tools and do well with our tire pressure monitoring systems
and about the wheel balancing....Aaron got his scratched up inside the wheel from the infiniti dealer since the weights were hard to remove since they were stock weights but not sure if discount would have done the same
I would stay away from Y spoke wheels. Don't look that good on FX IMO.
I didn't have any problem with my install. The guy that did my install was VERY careful. He examine each wheel and run his hand over the surface of the tire changer where it come in contact with the wheel before lay it down. So I guess it all depend on who you get at the chain store.
So I learned something new yesterday about my wheels while driving on them. It has been raining a lot this past week and water has collected in the barrel of the wheel. There's no real way of this draining out, unless you let it evaporate or soak it up with a towel. The other day on the expressway, I had a bad vibration going 75+mph. The water in the wheels is causing this imbalance. I contacted Interad and was told this is normal for this design of the wheel for water to collect. I did some online research and found out other manufacturers, like HRE and iForged, have the same issue too. The design is called reverse drop center. The dropped center allows a larger center to be used (diameter) giving the wheel a more open appearance. So I guess it's just an inherent design of the wheel that I will have to accept. I did find that iForged came out with a water diverter that I may look into:
http://www.iforged.com/press/august10/august10.php
In the meantime, I'm going to use a can of compressed air to blow the water out. Thought I would share this with you guys. Something new that I learned. :alien:
