Had to replace my fog lamp housing assy. today due lens breakage. The dealer charged me $170.00 for a factory replacement. I've seen them on the internet for about $80.00. I would have taken pictures, but it takes too long to post them, So just using words...
I removed the plastic skid plate (same one you remove to change oil) after I was done,I don't think this needed removed after all
remove the front wheel
remove the foward inner wheel well. (3 bolts on bottom, 2 phillips screws along the wheel lip, & 3 of those plastic push pins that you pry up the center section. 2 are facing the engine compartment, 1 is facing up in center of wheel well, be careful not to damage the 2 other plastic tabs that slide over some tabs along the wheel well lip)
now you can get to the 1 screw on the back of the fog lamp housing, you will need a 1/4" drive ratchet, a stubby screw driver is too long due to the windshield washer reservoir.
As mentioned above, after removing the screw, at the bottom of the fog lamp housing bucket is a tab that you need to pry down while pushing the housing assy. fwd.
That’s it. Now just re-assemble.
