Some photos of my ride
today i've installed H&R springs
Befor installing springs:
wow that looks incredible....looks like a bigger drop than the eibachs. I know there is a slight difference between the two but this seems quite a bit of a drop more from the pics...maybe wheel size different? I wonder how this would look with the 21 FX50 oems
I also noticed that and i think it is because of the FX50 setup. The FX50 sits lower stock than the FX35 so a 1.3/1.2 drop will be more noticeable. The 265/45R21 has the same diameter as the 265/40R22 so i don't think it's the tires.
You are right. diameter of new 22" wheels and stock is the same.
Springs give drop 25mm (the dealer of H&R in Russia tell me such info)
I will make better pics today
George drop looks awesome awesome, but what about camber and toe? Do you have a printout of your alignment and/or pictures of wheels from the front and back?
How does it drive? Did you have to do anything special? I thought because we have the adaptive suspension, it might screw some stuff up no?
Became a little tougher on hummocks. Nothing oobennogo did, just put new springs and everything. The only thing is that I did not do alignment. no equipment at 22 drives. A drive to another service all the time no. But while driving did not seem to have and the car behaves as it used to behave.
If you still want to maintain a more comfortable ride, then I would advise Eibach as friends on G35x say that with the Eibach suspension did not particularly rigid
