very easy mod... the only time i really worked on was prepping, giving even coats, and wait time... otherwise very simple.
remove top clips (i have 6 total)
left top clips removed
top right clips removed
left bottom clips
bottom right clips
prep materials used
1. water/alcohol mix bottle
2. Rapid prep - removes lubricants
3. 3M 1200 grit sand paper
4. bucket of water/soap mix for wet sanding
wet sand grille
1 can of Krylon Fusion Satin Black / first coat
after 5 coats
gave it 3 coats of Krylon Fusion Clear Coat paint then after 1 hour drying i installed it back on the front bumper
oh at the same time i gots my new plates... nuf said!
left bottom clips
bottom right clips
prep materials used
wet sand grille
after 5 coats
