- 2009 FX50S
If u do the paint chip repair with langka do leave out sumwhere warm for at least 24 hrs. Don't make the same mistake I didI have to redo mine in spring
Everywhere it's cold around here, but I was probably going to use a hair dryer a little bit and leave it probably for 48 hours because it is like 50, then low 30 at night now.
I would definitely want to wait for the spring, but the problem now is I'm worried about not covering up the chips before salt is covered in my car for the next few months here in Michigan.
Just curious, what issues did you run into that you need to redo it in the spring? Is it worse than it was before, just curious what the issue is?
Also, this video is a great video on how to do it....it was entertaining watching these two videos also....I'll probably post these on Fire's DIY Dr chip thread too since I'll be doing the langka system.
http://www.camaro5.com/forums/showthread.php?t=80059
