no, haven't needed to do it, but should be really straight forward... the lower arms will need to be pulled in a bit so the slots for the spring bucket arm would need to be opened up a bit towards the inside, then gotta see how the toe one needs to be slotted, don't remember if that one needs to be slotted in or out, probably towards the inside too, but the sub frame is aluminum so shouldn't be too hard to extend the slots a bit. a die grinder would be perfect but even a drill bit side loaded should work, even a file would work too. I'm curious to see how lance makes out with his because the right offset bolts would probably be the easiest thing to do if you can get what you need... I may have everything needed for these sitting in my garage honestly, but since I never did it I'm not sure enough to advise exactly what to get or what will & will not work... viet had a post about this a while back, I'll see if I can find it...
---------- Post added at 05:28 PM ---------- Previous post was at 05:24 PM ----------
ok, check this thread: ///209&highlight=camber+bolts
seems he started out trying to machine suff to work but by post 51 found off the shelf kits to put this together I think? also, looking at his pictures reminds me that for slotting you may need to flatten the little raised step that the washer leverages against for adjustment... still not a big deal to do really...
