ImportImage
- Cape Coral, FL
very good, they should be noise free.
Warranty goes like this. first year, anything breaks (99% no issues) you get it replaced free.
For the rest of the time you own the vehicle you can rest assured knowing that the most a replacement will cost you is $95! that means even if you put 100k miles on them a replacement is only $95! whatever breaks they do not rebuild, they will send you a new part. no other company does that. the other guys will charge you $250 per coilover and give you some serious 1 month down time. this would be a quick turn around just depending on how far you are from FL.
best regards
Josh
www.importimageracing.com
I would go with BC Racing parts over Megan racing, they are probably made in the same place in China but Megan racing is pretty much the outlet division of alibaba manufacturers. They offer a lot of different things and are good at nothing. Pete at BC is at least an enthusiast.
Thanks. So no forum special for these?
Man, so tempting...
sorry no such thing as a group buy for these, anything below 999 has no warranty as they are not a valid bc dealer/distributor
So true. Also, sweet new avatar Carlos!![]()
