hey guys just installed a k&n drop in today in wow im really happy with it . i could feel the lil extra power and u could hear it sucking air . gas milage is better . best $50 ive spent on the FX. i got a couple questions though . how often do u clean the filter ? it says million mile warranty but does it really last a long time ? and how much is the cleaning kit ? my bad for the kinda nooby questions . this is just my first k&n filter ive ever purchased . not familiar with them .. thanks guys
My two cents -- if you don't dyno tune your car, the best air intake is OEM with a drop in K&N filter. Fully sealed from engine bay, MAF sensor in the position where it's made to be and flow of air where ECU can compensation accordingly.
1) Reset your ECU if you can.
http://www.technosquareinc.com/350reset.htm
It will take some practice... or you might get it on the first shot. I found it fun to do. Simply removing your negative battery cable won't do the trick.
2) Is an oiled filter bad for Nissan MAF? Yes and no. OEM nissan are paper filters and yes they have oil on them. New K&N are properly oiled, but people over oil and you can get surging problems. Easy fix, quickly spray MAF cleaner on the MAF sensor to clean away the oil.
3) Dirty K&N filter to an extent is a good thing. Helps filter more particles per website recommendations. Tiny particles can pull the oil off the filter, so if you do a lot of off-road or know the air quality is bad, I would wash the filter and re-oil more often.
4) I would go 40k-50k miles before you clean. No need to do earlier, you just wear out your filter, but your filter will outlast your car.
5) When you do re-oil, only oil the side the air comes in from. You do light coats until the side the air comes in from is a deep red and the other side is a light pink. To give an idea, my aersol oil takes 10 or so very light coats. I wait 30 minutes in between coats to give it time to absorb.
6) Put that K&N sticker on top of the box so mechanics won't mess with it and try to say your filter is dirty and give you a generic brand and install for $100.
