DaChoZn1
- Houston, TX
Yes, I did a search before posting.
I've done my home work by reading several postings here on this topic. From what I've gathered, most members are using Ichiba or H&R spacers. However, I still have a few questions that I haven't been able to find the answers to.
I've read a few members using/recommending 25mm spacers up front and 20mm for the rear. I'm leaning toward V1 or DRS types instead of the plug & play.
1st Question: Since I can't seem to find Ichiba V1 or H&R DRS in 25mm, I'm assuming that members using 25mm spacers are using V2 or DRM for the fronts?
2nd Question: Since OEM wheel studs are 30mm. From what I've read, If I were to go with 25mm front, 20mm rear, my new studs need to be 55mm front, 50mm rear. Is this correct?
3rd Question: Do either Ichiba or H&R spacers come with the corrected stud length needed? In my case 55mm for 25mm spacers, 50mm for 20mm spacer.
I'd appreciate any information you guys may provide. I'm ready to make my purchase but want to avoid any potential headaches with the installation. Thank you in advance.
