Sean, it looks fantastic.
Darn you Sean, now you have me thinking of the rear spats.
Baking is pretty straightforward. Basically preheat the oven to 400, shut it off, and then put your headlights in for 4-5 minutes, pull it out and slowly pry apart.
Details here: https://www.infinitiscene.com/search/1/?q=90-Take-Apart-Those-Headlights
They are 22" x 9 and I run 25mm spacers all around.![]()
Ok, best option is to keep both sets. What's your 22s width? Maybe they're too wide that make the steering a bit heavy instead? The shorter side wall on the 22s will give you better handling.
That first pic seems like you had some tire rub. Hope its all better now.
Good to hear its finally alive. Is the Transgo shift kit next on your list Mike? You'll love the paddle even more.![]()
So you already had a 14K spring in there? And it was sagging that much? Wow. Normal spring rate is 12K. How much longer is the new spring? And FWIW, it's not going to settle so you don't need to wait to drop it.
Are you sure about the part number? The rear on my OEM was 260 62 -260 -12 and my 14kg springs were the exact same length, just thicker. The front is a 220mm. I looked into getting shorter springs from Zebra and he confirmed that the shortest spring they make in the rear would be a 203mm which needed an adapter. So if you got a 180mm spring, it may have been the wrong one which would have lead to the rear being so low.
