How do you replace that red reflector with clear? Looks neat
You need the reflectors from a red set (I have some if you need) the lights need to be cut apart and you need to take the chrome inside off by unclipping it from the LED array and then you can swap out the reflectors.
Thanks for the info man. I'll hit you up if I need the reflectors.
I wanna see if I can so the euro mod as well. I like the idea.
Did the gas gauge level fix today, the first time I did it was about 8 or 9 months ago and this is only the second time Ive had to do it. My needle went from 1/4 to a 1/2 tank when I was done.
Can you tell what's missing?
Decided to clean up the engine bay some. About to order some polished parts so I figured I'd get things ready by doing a wire tuck. Started with the drivers side harness.
FINALLY started up the sound deadening project again. Finished the first of the rear doors tonight. Not as bad as I expected. Thanks again to Soonster for the B-Quiet.
