Switched out the snow tires for the 21'' summers. And the golf course opened today. Spring is here. Gosh I missed the FX50 rims....they look soooo nice after wearing the snow tires for such a long time.
Same here Jonas, off the winter boot and on with 24" summer dress shoes.
Looking gooood. We need to set up a meet. We are almost twins. Although from the looks of it you're the twin that takes better care of yourself.
Thank you! I just got this fx about a month ago.. The replacement to the other one but I do baby all my cars.. Especially this one
---------- Post added at 09:47 AM ---------- Previous post was at 09:47 AM ----------
And yea we do have to set up a meet soon
3 more weeks for me.... can't wait to put them on:smile (2):
///8988[/ATTACH]
Hopefully the won't look like that with the adapters on
///8989[/ATTACH]
How much negative camber can I do without ruining my tires?
Any negative camber will eat ur tires out.. The more the worst lol
---------- Post added at 11:44 AM ---------- Previous post was at 11:43 AM ----------
What's worst than camber is toe being off
Tow kills tires, A little camber never hurt nobody :tongue:
i was running -3 and a bit for a whole summer before i got the alignment bolts with no noticable tire wear
For the rear you will need 2 of spc kit # 72265
if you have gtspec bars I have longer bolts to bolt on the shorter one
Im not sure the exact amount but my camber was pretty bad in the back -3.something and I was able to get it back to spec
I will see if I can find my alighnment sheet
I am lowered on h&r my camber was bad an my toe also
My tire was bad also
I need that spc kit is it hard to install?
Hear you have to drill something?
Agree with Jeff. 2 SPC 72265 kits and a set of Jeff's custom longer bolts if you have the GTSPEC lower rear tie brace. The one that bolt to the spring bucket. I got my within spec, but the tire poke out more on the passenger side then the driver side. I crawl under the driver rear, loosen the bolt and push out some more for more flush look, went back to have the car realign again and now if a -1.6 on the rear. I guess I was greedy with try to max out the stance and it turn sour. I suppose I can give up some flushness to get the rear within specs again :smile (2):
^^dam, didnt know it can be that bad with just H&R's on? thought coils are worse...
I also swapped out the winter wheels for the summers today and finally gave her a wash after a long winter
I applied a few more coats of Zaino today so I should be good till Summer :smile (2): ! I've owned my FX for more than a year now and I still love how sexxxy it looks ......... probably more so now than the day I picked it from the dealership !!!
