Just been informed my package has arrived at the house...finally getting the rear lateral brace! Thanks to b2autodesigns. Happy with their support and can't say enough of how quickly they got it here!
I don't have a garage... Do you have a driveway?
SfmDRuT2
yes. ok ok you got me. im lazy lol
---------- Post Merged at 06:02 PM ---------- Previous Post was at 06:00 PM ----------
. btw how many quarts do i need to fill back up? also i drained filled the tranny couple months ago so jsut waiting till next year to do the install
Update: Leak found. Door seal is crumbling away. Local stealer wants $150 and cant get it until Monday. Ugh x3.
SfmDRuT2
Ugh x4. Though my driver side seal is hosed, it is not causing my leak. For one thing the geometry of the chassis makes it impossible, and even if it was possible, the area inside near the torn seal is dry.
However, upon further examination it turns that ALL of my floormats are wet (front and back), as is the carpet in the areas under where the mats normally live.
Looks like this weekend will be spent diagnosing this issue. Great. :(
I'll make a new thread for this issue in a bit.
SfmDRuT2
Today @ 44,800 miles..
Drain & Fill
* Front and rear differential (Mobil1 75w90)
* Transfer case (Mobil1 ATF)
* Transmission (Matic S)
Used Silicon spray to recondition all the rubber door seals
