I used to have wooden ramps similar to that, but they were just too darn heavy to tote around. I now prefer my plastic ramps which are light yet are rated for 12,000 lbs for the pair.
yea they are heavy but i feel much safer under the fx then on plastic. Im waiting for a sale on a jack and stands. ive never used jacks and stands but eventually i want to put the fx on 4 stands. where would the jack and stand points be?
made another 2 ramps for the front. Loving it! Snow mode worked awesome getting the fx up there
really nice ramps!
---------- Post added at 09:32 PM ---------- Previous post was at 09:32 PM ----------
Removed the plasti-dip off of my grille, I'll reapply it over the summer break.
how come you removed it and how long did you have it on?
Aside from washing and waxing ........... I was able to apply these :smile (2):
today I played around with test fitting the beginning stages of mock up of my body kit. I will need 2 nice sized ducts on either side of the front bumper for the 2 side mount intercoolers but really want to avoid the whole cayenne type look and shape, also will help a lot when it comes to building and mounting the intercoolers in knowing exactly where my grille openings will be.
you do need a little imagination to visualize how this might look all grafted together, everything will be grafted together to form a one piece custom bumper cover, it will not be a separate add on lower spoiler type thing. the pictures of this clamped together on the bench are with the lower part raised as much as possible relative to the fx upper half but it will wind up being a little lower than as shown clamped here. this in no way really shows what the end result will look like, it's just a starting point but it does give a hint to the direction I'm going. the 2 side openings will probably be enlarged a bit from how they are here
I do not want a fiberglass bumper or any fiberglass or bondo anywhere on the fx really, everything will be still be flexible urethane just like original and it will still mount and install/uninstall just like the stock body parts.
here you can see how much lower it is than the stock one would have been. it will actually be slightly more than this even but I couldn't clamp it lower and have it still stable for pictures
and here are a few shots of mock up to another fx... front looks high because it is raised in these shots
John I really haven't followed your progress as I've been off forums mostly for a while. Is it running? When are you coming back to the track to check it out? :)
Looks good! I've thought about enlarging the fog light openings on mine before to incorporate an intake air duct but sadly I lack the skills. Are you using the OEM fog light brackets or did you make those?
I watched the wife drive away with it. I decided this weekend would be great weather to detail her Sienna inside/outside. And can I just add that I hate white, single-stage paint. All-in-all it looks like brand new though.
ha, you just drilled a hole without taking everything apart on the inside first? I'm doing the same thing right now, drilling for these dampener adjusters on an fx in my shop but I took all the inside panels all out... your way sure looks easier :) without knowing exactly where it would poke through I didn't want to take a chance... that may prove to be the most practical way to do it really once it's confirmed where it does poke through :) you really should try to seal that opening as much as possible too.
Kieran not running yet, the headers winded up being a huge setback but I'm still at it, should be running this year... I hope :) don't worry as soon as I do get this thing running as it should I' will be busting your chops for some track time :)
Took her up to the snow with the family.... Wrightwood.
Sent from my Thunderbolt
Ya I started taking the interior apart but I started getting frustrated :mad: so I drilled a very small pilot hole and had my sister check on the inside where it was ending up. When she said she saw it I checked where it was and liked the location so I went threw. I plan on putting some silicon in the next weekend so no moisture or anything will get inside.
Also I just finished installing my HID reverse lights thanks to Bklynjohn's DIY.
Sent from my HTC_Amaze_4G
