Maybe if you only get just the paint done, I could see $20 for a good hand wash. I do $50 for a wash, clay if needed, and wax and that's pretty cheap compared to most.
Changed my diff fluid and got the HFC's put on finally!
My god I love the cats! Car has no hesitation on launch now, just seems to take off! Also spins the rear tires more on acceleration from a stop.
I got a code though about one of the O2 sensors getting a strange reading so hopefully the tune can take care of that. Also, there's some bad resonance if I floor from a stop for about a half second where it just sounds horrendous.
Just did my spacers today.
Ichiba V2 25mm front
Ichiba V2 20mm rear
Thanks to Charles at B2 Auto Design for his help and the sweet deal.
Real easy to install.
Awesome stance.
Improved stability.
Told my wife it was a "safety" upgrade.
:wink (2): :confused:
FYI : Driveway picture is BEFORE spacer install
spark plugs, belts, oil change, tranny fluid, front & rear diff, airfilter cleaned, cabin filter changed, steering rack tightened, sport headlights, steering fluid swapped. so much stuff over the weekend. oh.. also drain and filled my fiance's tranny fluid on her crv.. i'm probably forgetting something.. oh yea. sleep.. good night!
pick up a pair of O2 spacers, best way to get rid of the problem. tunes not going to do it.
I know with Osiris you can turn off certain codes, so at least it won't pop up anymore. I'm going to see if it comes back though, because I thought HFC's didn't usually throw codes. Only thing I can think is that apparently Z's in 2007+ had more sensitive sensors, so maybe I have those.
Ichiba V2 20mm rear
Awesome stance.
Improved stability.
That looks real good
Damn someones been really busy. :tup:
Nismo install completed today. It's everything everyone said it would be and more. I would even venture to say there may be a hair more low end :)
