Thanks Ed, Up or downfiring is the way to go if your trying to save space with a box, still got room for 8-10 grocery bags when needed. I want a custom fiberglass enclosure made to add a 15" T0 or T1 to the 12s when I can afford it.Wow... I bet that system rocks the entire block... I can't imagine sitting in the rear seat of that car.
It doesn't take up as much room as I thought.
The Interiors are still stock, to be honest I think the bose system works very well If tuned correctly without pushing the subs to the limit. The JL sweep cleans up the bass very well and the external gain knob is badazz for quick changes of music. I'm content for NOW. I've always had a system in my cars and this one is no exception. I want to change out the information screen to a led display, relocate info above, and add an audiophile deck. Only after time and testing will I know if I need to start swapping internals. I've only had the 45 for a little more than 3 months, easy now one step at a time. I'm on mod 12+ now, that's almost one a week, I think there is something wrong with me lol.Did you replace all the speakers in the car, otherwise I would think it would SERIOUSLY drown out stock speakers. One solid 10'' sub with good amp can easily drown out the stock speakers and amp. I can't imagine with your system or why you would do that all unless you did redo all the speakers and oem amps? I know some guys that have done that and their car sounds 100 times better than some nice house surround sound systems.
In one of my previous rides, I used to have a setup like yours, but because it was so powerful, even with a 2 farad cap I was diming the lights, etc and I had the gain at around 30%, but it's just a big waste, hard on the electrical system and tons of space and weight that wasn't necessary. I removed half and had the same exact sub sound/feeling but half the weight, space, etc. Unless the sound system is mostly for show, that's a different story.
good luckk !! im too scared to pull the trigger on this on my baby, post pictures up when your finished !
I had these subs running in my Camaro SS Vert in a custom downfire box I made.hmmmmm ok. I figured for sure you'd be drowning them out but maybe you are running the gain really low. What RMS are they and what % gain do you run the subs when listening to music in the car? Are you running a capacitor (what farad)? Did you bolt the box to the FX?
Let's keep it above the belt, eh Chuck? I'm smart enough to catch that.I agree. People tend to get caught up in having a box the size of Texas and thousands of watts, thinking that's what they need to get lots of bass. Then they end up using it at 10% potential all the time. A well thought out system with properly matched components can sound great and rattle the teeth out of your head with very little. I've seen with my own eyes, a single 12" woofer in a bandpass box with 500 watts behind it outperform eight (yes EIGHT) 10" woofers with 2000 watts, caps, dual batteries, alternators, etc... in a decibel contest.
A perfect example of more money than brains losing out to a well planned system.
It comes with the Clean sweep, just have to spend the time to run the wire, remove the blank, drill a few small holes, hollow out the back of the switch to fit the remote module then re-assemble. Next time your out this way I can give you a listen if you would like. No worries man, just standing my ground.I like how the switch looks OEM like! Where did you get it?
Looking good. Better pic coming soon?installed the skid plate under the front bumper(thanks la_35fx) and took this picmy parking lot was empty at 6 am!!
