question, if my moms fx35 makes belt squealing noise on a cold start only IF she turns her steering wheel all the way to one side...and afterwords the sound goes away....and it doesnt do that any more once the cars warmed up....could it be belt issue? cuz recently i changed the belt on the car....and the sound started then.....i couldnt get gaterback so i went with duralast....the sound isnt like typical bad p/s pump sound, its SQUEAL! like belt squeal.....should i just go change the belt? and also could it be because the belt is on too tight? thank you
should i change the belt? or tighten them? cuz it only makes squealing sound the steering pump on load...
