F
FXPS
Guest
Hey guys for a couple of weeks now whenever iam stoped holding the break my rpm which is in between 0-1 goes up to one and down to between again what can that be from?
a intake/ vacuum leak.
have you done anything with your intake (or that area)?
Where abouts should I check for said issue, I have a similar problem and this might be it? I can re-tighten the clamps on the intake tube some more, and check the vacuum hose. Maybe when I get back I will take it all apart and dust off the filter, clean the TB plate, and give it a full check.
